It has at least 2-3 inches from the turbine. If should not be a problem at all. If it does which I dont think so, I would put in a turbine heat cover and reduce at least 50-60% of radiating heat.
Actually, if you put the oil pan fitting a little lower, then the oil from the hose might not be able to drain out at all due the oil in the pan backing up and block the hole. How about getting another same oil pan, cutting the hole from the first oil pan bottom and weld the lower part of the second oil pan to it. And then, move the fitting 1" or 2" lower.yeah, i think it's a "bit" too level there, i'd go for another inch at least.
you can;t weld the hole up where the fitting fits into the sump and re-drill it just a shade lower...? some gravity drain is better than no drain, which that is very, very close to.
Yep..Yep..Yep. I completely forgot about the crossmembers..etc. Your new angled turbo will drain just fine. But...how about when you go down hill? How much of an angle is enough for the turbo oil to still be above and drain to the oil pan in this situation? A few seconds is fine, but a few minutes is a problem.Steve,
Nice thinking but NO.... If you lower the pan or the housing then you are affecting the cross member and other parts.... Not going to work. I knew you boys going to fight about this so I spent an hour in my garage and tilt the turbo about 1.5" higher. Now here is the new picture of the oil drain.
