Jesus-Ninja
I've dug up a few threads on this where people have talked about doing it, but then I've also not read any threads where the success or failure has been discussed. I guess no news is good news, and I didn't find the site littered with horror stories, so....
My plan is to run a flywheel to suit my needs and sandwich the stock 1UZ flex plate between my fly and the crank, but I just want to be sure that the flexplate, having no torque converter bolted to it, isn't going to wobble or be unstable at high revs. I'm sure it's fine, but I wanted that warm fuzzy feeling of experienced reassurance![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
On the subject, I have two ways to skin this particular cat. First i can do as above, bolt through both the fly and the flex with longer bolts. Alternatively there is an option to make up a flywheel to bolt onto the flexplate where the torque converter used to be bolted. In many respects this might be easier, but I'm conscious of the fact that the delivery of power to a torque converter is different to, say, a paddle clutch, and I'm not sure if the flexplate and bolts would be up to it.
Any thoughts on either approach?
