When you shut the engine off does the IACV click a few times and perform its reset ?
Just unplug when the car is surging, idle should then stabilize and given RPM.
It does not, when the car is off there is no reset or anything after power is off.
When it's surging I did go ahead and plug off the plug and there was absolutely no difference. I finally of course after I finished found a perfect wiring tutorial guide swapping the exact same ecu into the exact same body harness and they have it wired extremely differently and I think I get what the main issue is.
The reason this problem presented the way it did for anyone reading this in the future is because other then being the wrong way to wire it up there is nothing really stopping at a base level from working and driving, but your start running into snags
Though everything runs fine with the way it is there is one main issue, the lexus ECU cannot control the Toyota EFI Relay and because of this key off = everything's off. This also easily checkable by running a test light in B in your diag box on the engine. There will be power on the B port for 3-ish seconds after. That is your sign your ECU is successfully able to control the IACV reset and MREL, instant power off= somethings fucked.
for anyone who finds this in the future after a long night again of analyzing...
I was initially using
il1 #2, #3 #12 #13 all going to toyota ih1 #14 (igsw)blk/rd
il1 #7 (Blk) going to toyota ih1 #22 (sta)black/w
e11 #4(blk/or) going to toyota ih1 #10 (mrel)blk/g
e11 #5(yel/rd) going to toyota ih1 #3 (cel)v
e11 #6(grn/rd) going to toyota ih1 #6 (FPR)blue
e11 #7(wht) going to toyota ih1 #7 (acmg)blu/ blk a/c not need to start
e11 #8(grn/blk) going to toyota ih1 #23 (fc)grn/y
e11 #19(grn/wht) going to toyota ih1 #5 (brake)grn/wht not need to start
e11 #26(blk/yel) going to toyota ih1 #16 (Batt)wht/red
And this was causing a myriad of issues and is not the right way to do this it seems, again mainly the fact the EFI Relay wasnt being controlled by the 1uz ECU
This is what I am switching it to
Toyota -- connector/pin/wire color - Lexus -- connector/pin/wire color - circuit description
IH1/22/BLACK - EB2/1/BLACK - STARTER B+ CONTROL
IH1/14/BLACK w/RED - IJ1/3,7/BLACKw/ORANGE - COILS/IGNITERS/INJECTORS
IH1/16/WHITEw/RED - EB2/2,3/BLACKw/RED - EFI MAIN RELAY VOLTAGE (B+)
IH1/10/BLACKw/GREEN - EB1/4/BLACKw/YELLOW - ECU B+ FROM EFI FUSE
EB2/6/BLACKw/YELLOW - EB1/8/BLACKw/ORANGE - EFI RELAY CONTROL ON/OFF
I took care of most of these tonight but I will go ahead and finish up tomorrow and write back but based on my symptoms and testing it seems to likely be the case. This link is such a lifesaver
Engine harness connector ID's -- 1994 4Runner/1995 SC400
www.uzswap.com
