C claxby New Member Feb 3, 2024 #1 have a landcruiser 75, fitted 3uz and 5 speed auto box, any ideas how to get the reverse lights to work off the shifter or the ECU,they are currently currently switched of a switch on the dash....
George_R Well-Known Member Staff member Feb 22, 2024 #3 sure just look at your 3uz wiring diagram and connected reverse lights per it
C claxby New Member Feb 29, 2024 #4 George_R said: sure just look at your 3uz wiring diagram and connected reverse lights per it Click to expand... George, do you have a diagram ?? is there one on the forum ??
J JZH Member Mar 2, 2024 #5 I don't know anything about the 5-speeds, but that should be your circuit. IIRC, the Neutral-Start switch N1 is on the trans. Ciao, JZH Attachments back-up light-r.pdf back-up light-r.pdf 26.9 KB · Views: 3
