i should probl post this in the trans and drivetrain section--but anyway..
i FINALLY have gotton a chance to get trhe car back to the shop..
if you guys remember, rdm had locked trhe differential which broke the input shaft of the trans..
i switched out the diff and switched out the input shaft, but did not go into the trans.. i also made the new intake with the 8 aux injectors and installed at the same time.. long story short, i thought the trans was "not right" and asked rdm not to drive it.. well i was finally able to get the trans on a table and pulled it apart-- and yes there was damage to the internals.. a sprag or sometimes called a one way clutch-which is really kinda a one way bearing--failed..
the "shock" of locking up the diff which snapped the input shaft also damaged the sprag.. the trans would still work, but in some forward gears was struggling.. mind you, it was not slipping, but felt like it was in 2 gears at once..
upon dissasemby, the previously installed blue clutches looked fine, although i will need to change some out..
i will need to replace the sprag, and a few hard parts, but do have a few spare trans around..
i might be able to get it together this weekend--i know rdm is counting the seconds..
before i decided to take it easy on the car i had rough tuned the 8 aux injector setup.. since, i have gotton a wideband and a data logger and a bunch of "cool stuff/tools" and i also want to get this thing running good/tuned and back to a track..
so if your in the chicago area, keep an eye open for it..
