My point is that the 7M bellhousing is the same thickness as the bellhousing you'll need on for the 1UZ.yes it´s a 7M bellhousing...and i want a drawing of the bolt pattern and not a buyable adapter plate...i know that this adapters are not sold everywhere.
I guess your thinking of an engine adapter plate to take an R154 bellhousing?
Which means if you put an adaptor between the 7M bellhousing and the back of the 1UZ you'll be spacing the gearbox off the back of the crank, which inturn means your input shaft will not sit in the spigot bearing correctly, and you'll also need to space the flywheel out the same amount.
Now this may not worry you are all, but personally, since there are bolt on parts off the shelf that don't have these issues, doing it 'correctly' is a no brainer.
yes i know that...and you are right...but the main reason why all these work... I dont want another cluth setup...so a new flywheel will be machined and the spacer between the block and the bellhousing and all is fine.
The larger holes on the centre ring are for the dowels.
