Parts R154 & 1UZ adapter plate w/bellhousing
arkannot86
Here's most of what you need for a 5-speed swap. You get everything pictured for $500 obo. The bellhousing needs fasteners to hold the trans/adapter plate together. Also a little notch for the bottom bolt on input shaft seal. I can put it together for a serious buyer
sup man i really want the tranny and the adapter plate can u get all the bolts and seals... and can u see how much shipped to 77085>
im not on here much but im a lurker... if u want u can text me 2817797777
That adapter doesnt look thick enough to work with a normal R154 input shaft length (should be +30mm?) sure that box isn't a R151 or something? Either that or is it an odd model of gearbox with short input shaft?
I have an R154 for sale in the UK if anybody is interested. I bought it for my '77 RA 28 Celica but I have elected to use one of my W58 transmissions instead because they ard smaller and fit the transmission tunnel better.
R154 gearbox.
It came out of a '93 Supra turbo with 40,000 miles on the clock. Drove car prior to removal. Perfect.
