the intercooler in question on ryan's car will be light years ahead in its efficiency. when you talk of placing ice cubes in your resevoir you must have seen someone who thought of the bright idea of cooling an intercooler with engine coolant that heats up to 200 degrees at all times... think about that concept and then you can figure out why previous attempts at water to air have failed. in this case the intercooler has a seperate heat exchanger that will mount where the ac condensor and radiator are. this serves as the cooling device for the liquid in the system. the liquid is then pumped through the system including the cooler. while air travesl through the fins in the cooler the water absorbs the heat and then carries it completely away from the cooler and then disipates it's heat through the rest of the system and the heat exchanger.
in the end though this intercooler will cool to 10 degree above ambient air temps into your throttle body. not to mention the pressure drop is significantly less. for every 1 psi lost in a fmic we lose roughly .3 psi. pretty good difference.
last thing to give another example of how a liquid to air intercooler functions. cook yourself some bacon and then as soon as your finish and turn off the range top. take that pan and dip it in a running kitchen faucet for 2 - 5 seconds and then touch it with your hand. see how fast water cools down heated metal.
david
blown engineering
if your not blown you just suck
david
blown engineering
