V vn1uz New Member Aug 3, 2007 #21 MWP said: Its a special (and expensive) nut that cuts a new thread as you screw it on. Click to expand... no its not its a bolt that bolts into concrete dyna bolt is a name ramset give to them they are a wedge anchor here is a picture
MWP New Member Oct 14, 2008 #22 Been a long time since i updated this. Bought a 1UZ from a JDM UCF11 halfcut. I have spent the last month or so tiding up, refreshing, removing & relocating parts on the engine. How the engine looked when i bought it Cleaned up with lightly port & polished inlet manifolds, etc, etc Falcon 110A alternator mounted up & ignition coils relocated Starting re-covering & rerouting looms And again... Removed trac control from throttle body Main engine loom tagged and ready to be re-covered & routed
H Herus New Member Oct 14, 2008 #23 Hey Mate, Can you send me a slightly more in depth idea of your wiring loom? Will make labeling mine much easier Edit: Just found your other thread. Thanks. I need to be invited to come and look at this thing Thanks, Herus
mshawari1 Member Oct 14, 2008 #24 very clean !! how you do that ? Attachments bh.JPG 9.5 KB · Views: 58
MWP New Member Oct 14, 2008 #25 The inlet manifolds and cam covers are painted, and the block has been cleaned with degreaser and a tooth brush. Took quite a long time...
spf_lexus Active Member Oct 14, 2008 #26 I used a lot of brake cleaner on my upper plenum and managed to take the finish off, probably will just bead blast the rest off and powder coat. How did you coat yours? regular high temp paint? or powder?
