Hi Craig,
Merry Christmas and Happy New Year!
Firstly, nice job with your conversion! Looks and sounds great.
Similarily, am a big fan of the 1UZ and have converted a Hilux Surf from a 2.4 diesel to the 1UZ with a little wiring help from Sideshow to get it running out of limp-mode. It was a tight squeeze at the firewall but in the end I was very please with the smooth power the stock V8 offered and would often hear people when stopped at intersections, talking among themselves saying, "That thing sounds like it has a V8 in it". It was also fun to pull away from the lights (manual box) and give some sportier cars a run.
I have a 6m Aluminium Stacer Sportster with the GM 181 (3L) on a Alpha 1 Gen 2 and am contemplating the same conversion.
From reading your post I see you had gone with an adaptor plate to marry up the Lexus block to the Mercruiser belhousing and have gone over-water exhaust with the water-cooled manifolds. From the photos it looks like you have two layers of adaptor plates sandwiched between to get the spacing right.
Just wondering if you still had the boat as I have moved down from the Gold Coast to Kariong (Central Coast) NSW and would love to pick your brain a little (over a beer possibly?) to help streamline my project before I commit to purchasing another engine.
I actually have two good running engines for my boat but would like sell them to help fund the conversion and ideally would purchase the parts over the summer and do the swap over the next winter.
Costing (approx.)
$1200 - 1UZFE including ancillaries (igniters/airflow meter/alternator/timing belts/starter bolt conversion/etc.)
$1100 - Exhaust Manifolds (Rolco)
$1800 - Heat exchanger and tubes/fittings (aftermarket?), any advise on selection would be helpful.
$???.?? - adaptor plate (any chance you have a template?)
$450.00 - Delows flywheel (reuse torqueconvertor ring gear)
$450.00 - Thru-hull exhaust tips and associated flexipipes
$400.00 - auto electrician for when I can't make it run properly again
Can you think of any other large costs associated to this swap?
Also, how did you blank off the stock exhaust port at the transom, just a plate?
BTW, the video sounds like the boat has a nice exhaust note but just wondering of the volume is offensive.
I am trying to keep the cost at around 5k if possible and will be doing the swap myself with my boy (12 years). In my experience these types of projects seem to take longer and cost more that originally anticipated so just trying to make an educated guess for the feasibility between this and just getting a different boat entirely.
Thanks in advance, Mike.
