time has come to make my own build thread, its been underway for about a month now(turbo build) but ive owned the car for 3 years, did the r154 swap last year. im leaving a bunch out, any questions just ask. i like this site better than clublexus, even if its slower. enjoy!
turbo manifold bits and pieces
http://i79.photobucket.com/albums/j1...der/turbo1.jpg
http://i79.photobucket.com/albums/j1...der/turbo3.jpg
koyo mk4 radiator, alum shroud, radiator hardlines etc
http://i79.photobucket.com/albums/j1...der/turbo2.jpg
dont worry all paint will be stripped off and final prepped before being coated/wrapped
http://i79.photobucket.com/albums/j1...der/turbo4.jpg
http://i79.photobucket.com/albums/j1...der/turbo5.jpg
http://i79.photobucket.com/albums/j1...der/turbo6.jpg
moved the ac lines, and modified the rear most cyl tube on the headers to clear a 3" dp with .5" to clear in all directions.waiting on a 3"u bend from summit to finish the dp to midpipe section.
http://i79.photobucket.com/albums/j1...der/turbo7.jpg
my DIY turbo brace, i have a tab on the WG dump tube flange also
http://i79.photobucket.com/albums/j1...der/turbo8.jpg
a lil i/c fitting, i need to weld them all and fit the bov flange
http://i79.photobucket.com/albums/j1...der/turbo9.jpg
http://i79.photobucket.com/albums/j1...er/turbo10.jpg
ran out of daylight before i could flip the intake manny around. well as promised...pics.
86 celica throttle cable, little difference on the stop. i cut off the big rubber piece and swapped it over.
![turbo16.jpg turbo16.jpg](https://www.lextreme.com/forums/data/attachments/22/22832-a00c9e3eac280988314124a1e726c122.jpg?hash=oAyePqwoCY)
turbo brace to block
![turbo15.jpg turbo15.jpg](https://www.lextreme.com/forums/data/attachments/22/22833-112b211b70e161abcca7ae67767683c5.jpg?hash=ESshG3DhYa)
turbo manifolds all ready to pop in
![turbo14.jpg turbo14.jpg](https://www.lextreme.com/forums/data/attachments/22/22834-1301f039134b4d145a37812c55d8dc16.jpg?hash=EwHwORNLTR)
had to cut the low beam off a spare headlight. ill re-aim my high beams to function as lowbeams. i used to get flashed all the time anyway with my HID low beams on, wont be anny diff with just hi beams, lol. but i have a spare headlight and a HKS mushroom style filter to put on if i need to. i like the idea of the intake being so far from the heat socked bay.
![turbo13.jpg turbo13.jpg](https://www.lextreme.com/forums/data/attachments/22/22835-4210b02f2637706709d00b2b3dd1c83e.jpg?hash=QhCwLyY3cG)
![turbo12.jpg turbo12.jpg](https://www.lextreme.com/forums/data/attachments/22/22836-5f3c4711e7e877aa321bf031bb20b8a8.jpg?hash=XzxHEefod6)
its just an SC
, i like cutting her up. muahaha
its just an SC
![Stick Out Tongue :p :p](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f61b.png)
