Hi all i need some help.
well ive just got to start on getting my project hilux surf with the lexus v8 1993 to run but its very poor running i had two auto sparkys look over the truck
one was right about the un starting ecu was damaged putting out 11volts to the ignighters units
fitted the new ecu now starts with very light pressure on throttle pedal
will not tick over tell it run for 2mins then ticks over but miss fires
when you lightly press the pedal it will rev up but holds back then rev will die off (like its under fueling) no power will still if you put it in gear Autobox still
http://s19.photobucket.com/albums/b162/gkperformance/?action=view¤t=4d783c87.mp4
changed the coolant temp sensor,plugs, leads
then got this
![](http://i19.photobucket.com/albums/b162/gkperformance/th_6fb31ee9.jpg)
today different outside temp 14c sunny
![](http://i19.photobucket.com/albums/b162/gkperformance/th_d6ebc52b.jpg)
just going around in circles need some points in what it could be
thanks for looking
then got this
thanks for looking
