Hi All,
Just a follow up on supercharger sizes, expected power, intercooling etc.
The Richwood manifold accepts all the superchargers listed with a variation in top plate, drive pulley and rear intake,
Eaton M90 ( ford T-bird, GM, Terra Charger.)
Eaton M112 ( Lightening, Jag, Magnacharger, Harrop )
Eaton M112 ( cobra, we now have a top plate & drive to suit)
Lysholm 1600, 2300, ( 3300.- tight)
Autorotor-Opcon 3150, 417, 418, 420, 422, ( 424, 426.-Tight fit)
Whipple 2300(W140) 3300 (W200)
Race and show applications;
GM 353, 453, 653, 471, 671, 871, 1071
PSI B & D series
We can if need be make custom top plates for those whom have found a weird supercharger flange.
The supercharger sizes are,
Eaton; Roots type
M90 is 1.5 litres per rev
M112 is 2.0 litres per rev
Lysholm; screw type
1600 is 1.6
2300 is 2.3
3300 is 3.3
Autorotor-Opcon; screw type
3150 is 1.5
417 is 1.7
418 is 1.8
420 is 2.0
422 is 2.2
I think you get the general arrangement, Whipple is rated same as Lysholm, and for those whom want serious boost, the PSI is 8.4 litres per rev.
The Eaton calls itself positive displacement, it still however pressurises in the plenum, the screw superchargers are true positive displacement with varying internal compressions, being from 1.2 to 1.45, we have found in most apllications with roots type, especially higher boosts,(8-15lb) you do require some cooling, whether that be water to air or water injection.
It has been our experience, that the screw superchargers in most cases do not require intercooling for low boost 6-10lb), a properly sized screw supercharger for the application and boost requirements will at best require water or misting only, in higher boost application (like Rod's)10-25lb, water or methanol works very well, we have placed water to air intercoolers in manifolds, both bar type and block, the result was minimal, but again this all depends on the tune.
The expected power gains again are something that many have varying HP results,
example; stock 1UZ-fe, stock computor, stock throttle body, etc,
HP from factory is 220hp, running an M90 with 7lb @ 6000, gave a 37% increase, (300HP) we ran a piggy back tuner for spark and fuel, a rising rate fuel reg, one range colder on the plug, free flow air cleaner.
Hope that answered some questions, any quires drop me an email.
Cheers, Andrew
[email protected]
