Dry sump
Hi Tomo, one of the guys in our car club is building a dry sump for his 1uz, i discussed with him the use of the fan pump, but he felt 12l was not enough, he is building his from scratch, and has moded the original sump by fitting a new bottom to it with a small trough running front to rear it is about 1.5"" wide and about 1 " deep, at each end he has a 1" fitting stepping down to about .5 " fittings , he has made up his own twin scavenge pump that will mount on a plate next to the alternator, the original oil pick up is cut off at the filter and extended to exit out through the side of the sump with a 1"fitting this will go to the output of his external tank which he is about to make also, sorry no pics yet but i will try to get some once hes made more progress,
Best regards
Lambo
