For anyone trying to relearn the immobilizer, here is the method I used for my sc430.
It’s best if you buy the immobilizer delete, it will just be plug and play. Less headaches. But if you don’t purchase the immobilizer delete, you’ll need to:
1) disconnect the negative cable off battery
2) remove the oem ecu, plug in the new modified ecu.
3) connect the negative back on the battery
4) insert key in ignition, and key on (engine off)
5) on the obd2 port under the driver side dash, jump terminal pin 13 (TC) and pin 4 (CG) for 30 minutes (put a timer on).
6) the cluster gauge will start flashing during the 30 minutes.
7) after the 30 min is up, key off and remove key from ingntion. Then remove the jumper wire from pin 13 and pin 4.
8) insert key back in ignition and start engine right away.
