i need help with my zex nitrous set up.
i do not want to cut my stock fuel line.
i been trying to find a tee that will fit where the fuel line comes apart.
i measured the fuel line treads as metric 1.00 and 13mm
the nitrous has a -4an hose.
what can i use to tee off the stock fuel line where it comes apart?
i have no idea what that metric fuel line male to female treads are called?
or what brass tee would fit in there?
a male to female to -an4 tee that fits the sc400?
is there a double banjo bolt that i can tap off the fuel rail?
the only photo i seen on fuel tap is someone cut there fuel line in half with brass fittings. looks so easy yet so hard to find the tee.
