well my finances are finally starting to become organized. i will be very bussy all winter with a new job but by spring work will settle down. im going to be purchasing a 97sc400. ive finally organized my thoughts and figured out my basic build sheet. i will be ordering a stroked 2uz built short block. im not sure what the displacement will be after it is stroked yet. how ever it will be a vvti 2uz.
im going to take the heads from the sc (which is also vvti in 97, correct?) and i will be giving them the full treatment. titanium springs and retainers, custom cams, so as to make them flow and fit the numbers i wish to achive. ive got a twin turbo kit in mind that can be ordered with s200, s256, s258, s362, s368, and s372. i have no idea what type of turbos these are and if anyone has info, id appretiate it so as to select the best one for my application. the kit also comes with twin turbosmart 50mm wastegates, coated headers and coated down pipes. this company also makes a trick 1uz intake manifold that i might use. 550cc injectors, walbro fuel pump and new rails to keep things wet. a tko will be in the works. im planning on having some work done to it though. im not sure exactly what yet but ive got some ideas. aem ems that id like to have rebuilt by an expert with these systems to do a couple extra things as well as a turbo and vvti controllers. trd limited slip differential, hooked up to a carbon fiber driveshaft, both for a supra.
ride will be taken care of by jic magic flt-fas coilovers, jic magic tie robs, jic front negative upper links, and tanable sway bars. i like to use suspension all by one company so they are designed to work together, i figure i will get an over better effect. uhm but yea thats basicly the technical side of what i'm tryna do. as well as some sweet carbon fiber stuff, im feeling a carbonfiber hood, trunklid, decklid spoiler, and then using carbonfiber vinal id make it a twotone carbonfiber on black. fighter jet sc470tt vvti! haha well yea those are my plans for the next 2 years, see you in spring with some pics of my future sc and soon to be a badas$ toyota rocket! hah
