hi all.
im about to start my twin turbo conversion to my 90 celsior, after reading the article on the main page ive decided to "give it a go".
im just wondering how effective this setup is, does it work properly?
ill be using 2 s4 rx7 turbos (as i have a couple of hiflows laying around
)in the same fasion as the one in the article, im planning on only running 7-8psi so is this ok with the stock engine management? will i need a rising rate pressure regulator? stock injectors ok? i will be using a front mount intercooler as well, just to keep temps down.
im also wondering where to source the external oil pump to feed the oil back to the engine, and what sorta specs sould i look for? i know it needs to be pretty accurate to match the oil going in.
keeping in mind this is all going onto a dead stock engine/driveline, will i kill it?
basically me and a mechanic mate are going to have a shot at doing this ourselves, so any advice would be appreciated.
cheers
cheers
