Another update, there's no RPM signal during cranking so the MS isn't injecting or sparking and is currently starting using only the cold start injector!! Once I solve this problem it should start up and run with no problems. The MS is providing fuel now (once the engine is running any way) and initially it was very rich due to a vac pipe leak but that is sorted and it seems spot on, having your map has made this loads easier. Thanks.
Robert
Robert
