bigdaddeywalt
hi joe , thanks bro. Your best bet will be to find a complete motor with tranny, wiring harness and stock ecu to start off that way you know everything you use will be compatible being there are many ecu's for this motor. What I have in my car now is a LS400 motor. The stock ecu runs the motor and tranny, in the wiring diagram it shows how the LS400 brings an abs ecu, fuel pump ecu, traction control, etc. We ddint hook up any of that, the only thing we are using is the ecm(ecu) My motor brings traction control but i changed the throttle body to a no trac one ane cut the plug from the wiring harness. They say the tranny wont shift without the 2nd speed sensor on the cluster of the lexus but we only have the No.1 speed sensor hooked up which comes on the stock wiring harness. Now I have no idea what the wolf ecu can do but if cannot control soleoids from a tranny then it will not work unless you go with a manual conversion which is expensive. If you manage to get the wiring harness with the ecu make sure you get all the plugs that plug into the ecu, 3 come with the motor harness and one normally stays in the car which feeds the ecu from the cluster and all, just ask your salvage yard that you would like that plug with atleast 5 inches of wiring. If you have anymore questions let me know how I can help you reach your goal. Take care Joe and goodluck.
