took it out for its maiden offroad voyage on sunday
i had it tiltrayed there and back because of no rego and is cheap really.
i had my mate in his duallocked and front and rear winched 75 series as my helper/recovery vehicle.it normally runs a set of 34" simex's with staun internal beadlocks but took the rd tyres for the day haha
i had no front tailshaft so today was more of give the engine a good run and try tune it a fair bit more and also just a general test to make sure most things were working before it does go for rego.
also had no snorkel so deep water crossings were a no no
all in all i am 100% happy with the lux and the only troules i had was the crappy ac delco igniter/coil pack failing and arcing on its bracket a quick adjustment away from the bracket and its was running smooth again.knew i shoulda kept the ***** gm crap of it.
and the crappy exhaust system i had someone make up originally failed on the bracket side as they only used crappy rubber for the hangers and it melted of.
and a small power steering leak that developed during the day
oh and a staked front tyre
as for the engine man i think its fast i would put it up to being not the same but close to the power of my v6 aurion it would pull second gear power skids,
me and d1 also had it running really smooth the engine wasnt moving at all at idle if it wasnt for the exhaust note u wouldnt know it was running
took it down the long sand straight acouple of times for power runs and to load her up and my mate can vouch for this its friggin fast i had it 4th gear flatout across the sand and the suspension took it sweet
we went to get a video of this but had quite a recovery emergency to deal with and ran outa time before the tilttray rolled up.
just acouple of pics
mate dan settin up for a pose
dan gettin ready to snatch the transit van lol
and these fellas we recovered were the same young dudes from a mareeba 4wd fun run day that were stuck down the back of the property, again no recovery gear and no idea if i new it was them straight away we wouldve kept goin
so the things that need attention are the igniter pack, a bit more adjustment for the gearbox x-member, reroute the extended brake lines so they dont rub on tyres at full lock, power steering leak, and another small sump leak which i allready knew about, and try figure out something with the stupid exhaust dont know wether to build my own stainless one now or after rego.
all small things which dont stop me wheeling it
also shut down a fella in a 75 ute tryin a hill climb i did it in 2wd lol
