All of you who are tired of those lo-res VR (mag pickup) sensors, and don't want to attempt the not-insignificant task of implanting 36 Hall magnets in a crank wheel, take heart. The Toyota MRE sensor has arrived.
MRE stands for "Magnetic Resistance Element" and Toyota has started using these for crank & cam sensors in the new 4.6l 1URFSE motor in the LS460.
Imagine a sensor that produces a crisp square wave like a Hall, but from a standard crank wheel - no magnets required. It's non speed dependent, so it produces the same square wave during lo-rpm cranking speeds as it does at 7000 rpm.
Denso who make this little gem say this about it:
Benefits and Features (MRE Type)
- High detection accuracy
- DENSO’s cam/crank position sensors use a unique arrangement of two pair of MREs on an IC chip, achieving high detection accuracy, including just after the engine starts. The MRE cam/crank position sensors have almost 10 times higher sensitivity than Hall element cam/crank position sensors.
- In DENSO’s MRE cam/crank position sensor, the molded IC chip is installed inside a cylindrical magnet, which means the IC chip is positioned closer to rotor gears rotating with the cam or crank shaft, providing even higher sensitivity.
- High reliability
- The molded IC chip and the cylindrical magnet are integrally covered with poly phenylene sulfide(PPS) resin for greater strength.
- PPS resin has high resistance to chemical substances including fuel, engine oil and emissions.
