Jake Breyck
wow those dont look strong.
no but im not gunna provide enough pictures to be able to copy them, They fit perfect, if you wanta set contact cjsupra90, his price is very resonable.
On a different note about UZ / MKIII swap mount, I have just recently redesigned the mounts and had the first set of components parts cut today at work (I love having a Laser cutter at work) Sometime this week I will get around to welding them up. The hole reason for the redesign is to allow for more clearance mainly on the driverside for header primary pipes. In the supra chassis, the clearance is very tight between the engine and the steering shaft. Stock SC400 manifolds bearly fit, but headers are virtually impossible. With the new design, there will be more clearance to bring the #1 and #3 primaries down lower for more clearance with the #5 and #7 primaries to the chassis rails and steering shaft.
from talking to chris about these the other day on the phone i got the impression it makes no placment changes just clearance changes, i offered to let him test fit them on my motor/car wile where dropping the motor in, so if we do that, well get some pics of the motor on his new mounts in my car.
we'll see, i still need the flywheel from super runner for this to happen, although im hopeing ill have it by this weekend.
Chris, does this move where the motor sits in the engine bay and/or how high it sits? Soon as I find a bell housing, you'll be the first person I speak with about mounts![]()
R154, std box. Adaptor is the from THOR as is the flywheel, clutch etc. It all bolts in and works a treat.
