milisakeracing
are you really planning on starting the motor up with no headers at all? dont do that inside or out of the garage. burning stuff is not the problem everyone has delt with a small amount of fire not a big deal, what is a big deal tho is the rush of cold air going back into the motor after each pulse, and colling off the valves whitch will destry them. you know what happens to hot things when they get hit with cold stuff? not good, dont do it.
although if its a motor you dont care about and wanta get youll jolly off by running it with no header its great fun.
if you just ment no exaust system bolted to the header thats fine go for it inside or out. the video in my build thead is open header.
No, it has the exhaust manifolds installed. There would be no way I would have installed the engine without the manifolds on as it would be extremely difficult to install them with the motor in the engine bay and I am not pulling the engine again unless either a) something catastrophic happens or b) I have a different engine to replace it with.
I have the exhaust manifold/cat flanges from Lex and most of my bends plus a y-pipe waiting to be cut and welded but I will be starting the car to make sure it can start and idle before trailering it to the exhaust shop. The two closest items to the exhaust manifold outlets are the ground wire to the transmission and the slave cylinder's rubber line (found out the other day while trying to bleed the master and slave clutch cylinders that they probably have to be replaced...yet another delay/budget altering item, lol).
At the moment sorting this wiring out is keeping me busy.
