edz
Megasquirt vs others
The Ford EDIS is probably very common over there, here you'd be looking at US$ 2- 300. Then the MS2 at $369 worked out at just over $500 Aus plus building. I picked up a sequential EMS 8860 for $AUD 1200 (about US $900) so it will be interesting to see how it goes. Good luck with the megasquirt, I'm learning lots about setting up computers reading the info you and others are writing up which should help me with my wiring.
Ed
Ah shadetree, I see where the confusion is. I beleive you are in Washington US, I was quoting $Aus, which are about 72% of a $US.shadetree said:I'm not sure where you are getting your prices from.
I spent:
$141.. shipped, Complete Ford EDIS setup, from Ebay.
$369...shipped, MS2 kit, relay board kit, stim, cable, from Glen's garage.
$510 and that includes the relay board, which is not needed for cars that are already fuel injected. That is the "good kit", MS2, v3.0 board. It does cost more if you buy it assembled and tested.
I already have a laptop and WB o2. I have a bit of experience with programmable FI, but am looking to learn more.
I see the value of a 1uz engine as being right around $500-700. I have a hard time spending 2X, 3X the value of the engine on the ECU.
Jerry, the trigger wheel mounts on the crank pulley. I was planning on bolting it to the pulley.
Ed
![approve.gif](http://lextreme.com/forums/images/smilies/approve.gif)
