UZZ30-Québec
I've got a hand on a full kit From a turbo supra
R-154, pedals, clutch, clutch cylinder, drive-shaft, diff etc...
I'm planning to install this in my LS400.
I know there's no hole or bolt on the firewall to install the clutch pedal, could there be any other major problems? I'll probably need a custom drive-shaft?
If i use the stock ECU and let it think it's in 1st gear (with ETC on power so the ECU won't try to shift the transmission), will I be ok with the engine?
Can i swap the supra LSD gears inside the LS400 diff housing? (i don't think so...) I've made a search on the forum and no one seems to have done this in a LS yet.
