xirforever
Ok so im going to need your guys' help on this one because this will be my first conversion of any sort.
Ok so where am i at right now... well I bought all the parts for my clutch pedal and master cylinder (bought the stock sc300 one) and drilled the holes and installed all the stuff yesterday. So im done with that hassel. I have the transmission (R154) and transmission mount, and im pretty sure i am going to extend the shifter myself rather than finding a soarer or chaser R154 box. I need help on deciding what clutch setup im going to use. So may the questions begin....
1.) When i extend the shifter, can i cut the linkage and weld on an extension? I heard they break if you do this sometimes, so is it just in the quality of welds or should i call up my machine shop and have them make me a billet one? Here is a reference to what i am talking about http://www.clublexus.com/forums/showthread.php?t=183050
2.) I plan for this setup to be hold a good amount of power (turbo in future is a serious consideration), so what clutch setup would YOU go with. The push type deal from CRS or Dellow (seems like its using the W58 but im not sure). Or just buy the bellhousing alone, have a custom flywheel made to suit my R154 PP and clutch disk. If i did that, the problem is the R154 is a pull type ive been told, so is it possible to modify the bellhousing from CRS or Dellow to accept my frankenstein pull type clutch setup? Id like to go with the second option because the r154 clutch is bigger, and my car not being exactly light with a lot of power id like that, it would be easier to drive around on and probably a little easier to hold power without going with a very high performance clutch. Also i have heard that a pull type puts less stress on my crank so it would prematurely wear out my bearings. What do you guys think? I want to keep this project rolling....
If i made any factual mistakes in my post, sorry, please correct me (have to start somewhere). Anything im forgetting and/or you want to comment on, please do!
Some pics of the clutch pedal
