milnersXcoupe
Forged from 4340 aircraft quality material
Fully machined to produce the lightest and strongest rod possible
3/8" ARP 2000, 3/8" ARP 3.5, or 3/8" CARR cap screws
Shot peened and 100% magnafluxed
Horsepower range is 575 H.P. at 8500 rpm
Horsepower range is affected by rpm, stroke and piston weight.
Above rods REQUIRE use of one of the connecting rod bearings listed below.
To order rods finished to the exact size for Federal
Mogul bearings, affix an “F” after the rod part number.
For rods finished to exact size for Clevite bearings, affix a “C” after the rod
part number.
In addition, you MUST specify which Clevite bearing will be used.
TOUR LITE® “ I ” BEAM RODS
4340 MATERIAL
Part No. Length Journal Size Center-to Center Big End Bore Gram Weight
14340-8 Stock Length Honda / IRL 5.700" 1.976" / 2.008" / 2.015" 525 / 530 / 538
COMMON FEATURES
Attribute Honda / IRL Journal
Crankpin 1.8885" / 1.8500"
Pin Bore .9281"
Big End Width .940"
Pin End Width .980"
BEARING CHART
Bearing Type Part No. Big End Bore Crank Pin
Federal Mogul 7195CH 2.008" 1.8885" Honda
Clevite CB1456P 2.008" 1.8885" Honda
Clevite CB1663 2.015" 1.8885" Honda
Clevite CB1664 2.008" 1.8500" IRL
Clevite CB1798H 1.976" 1.8500" IRL
Lengths other than these typical sizes may become popular after publication of this catalog.
Please inquire about lengths not
listed as we may have subsequently added applications.
Also, we can manufacture 40 pieces of these rods at special lengths for
no additional charge.
All connecting rods on this page are supplied with 1.600" underhead length 3/8" ARP 2000 cap screw fasteners P/N 42351.
Upgraded 3/8" ARP 3.5 cap screws P/N 42358 or 3/8" CARR cap screws P/N 42357 are available.
To order upgraded fasteners,
affix an “RA” for the ARP 3.5 or an “R” for the CARR after the rod part number.
part number.
4340 MATERIAL
COMMON FEATURES
Pin Bore .9281"
Big End Width .940"
Pin End Width .980"
BEARING CHART
