just fitted secondhand m90 with a a1 turbos manifold.standard 1uz early mid sump standard ecu and extractors. put on dyno yesterday.shows to have lean idle and leans off big at 5000 rpm. is 214 kw and 399 nm torque at 3500 rpm.as is with no tune. was told needs after market computer to make safe.recommends link g3plus or g4storm.to stop from leaning out and improve idle.does the standard fuel pressure regulator cope with boost or should i replace with aftermarket?what do u guys set your rev limits to with aftermarket ecu? standard ecu cuts mine at 6300.boost is 6psi.
