That is true, that if you have two same built engines running same boost tuned to the max, a supercharged engine will not put out as much power.
chrisman, is there more info on your turbo setup somewhere on this sight or can you give me more info please.(boost, rpm, injectors, actual fuel pressure,motor spec, etc)
