Get a dyno tune.... I think you are still little off on the fuel/air issue.
The ECU circuit might be shorted when you changed the current to the fuel pump. But it's just a guess. You may put back the way the fuel pump harness was as before. Also if you have the TPS code, that could be the TPS itself, ECU wiring, or the the ECU itself. I'd replace the TPS first.A bit of bad news....the damn ecu keeps giving me a TPS code everytime I floor it or get past a certain throttle angle. If I cruise and barely push it I can drive normally, but as soon as I push the peddle down 1/4 way the engine bogs down and bucks. I will follow all the wiring back to the ECU and probably replace the sensor.
When I swapped ECU's it solved it, but just today it came back in the morning. I tried my old TPS and it did the same thing.
One question, did I mess the ECU up when I left the jumper wire connecting the Fuel pump (FP and +b) test ports on the engine diagnostic box??
I hope it is not an ECU issue. from my understanding if the idle contacts of the TPS do not open when the throttle is at a certain point than the injectors will be shut and timing retarded.
any similar experiences????
It seems the idle contacts are staying closed even when the throttle is floored. The TPS sensor tested perfectly. I have continuity through each wire from the TPS. The ECM is the only possible problem.
