when i first checked up about these "JTG Liquid LPG Injection systems", there was very little info or write ups an there was no kits for cars, now there is but from only limited locations in australia.
____________________________________ http://www.lextreme.com/forums/showthread.php?t=9814
[FONT="]:sgrin:There is No substitute for cubic inch, except for BOOST !!!![/FONT]:sgrin::burnout:
"91 LS400" Argo rods, CP pistons 9:1, Custom Tighte Cams, Whipple supercharger 20psi, Torsen Lsd,
Dual TB's, Whiteline swapbars, 97 RZ Supra brakes, Airbag & controller
i rang around in adelaide and found that there were a few places that would do it, and most wernt listen online, so just ring around and hopefully you will get lucky..
just remmeber if u plan to disable the std injectors on a std loom u need to strip the loom down around the left hand rear section
then find the wires that power the injectors and cut them and put them on a change over relay
cause if u cut it at wrong spot u can loose power to any of the coils or the ignitors
