basslover911
SO, how does GM get their cars to run on only 4 cylinders while on the freeway? (does it simply cut off the signal to the injectors and turns four of them off? Just that?)...
I was thinking maybe, just maybe, I could put in a switch and everytime I hit cruise control four of the eight injectors signal would be cut, therefore only runing four cylinders at a time (and saving probably 5mpg if not more on the freeway while going at a constant speed and with the cruise control)...
What do you think? Am i completley nuts?
