-Nemesis-
Ok, time to brainstorm guys. I've a '94 Toyota 4Runner which now sports a 1UZFE engine. I'm using the existing radiator off the V6 for the time being, but occasionally the engine runs warm. It was bad last week, which I traced to an airlock, which solved it mostly. It ram a little warm today around town, now mind you though it was high 30's (celcius.)
It's running a single 16" thermo fan on the back of the radiator. Initially it was on the front blowing, which was better. But now that i've re-installed the A/C condensor the fan must go on the inside. I also don't have room for my dream fans, the AU twin thermos.
I want to make it run cooler, but the priority at this stage is $. Our wedding is April, and at this stage I can't justify the $1000 or whatever for a custom radiator. So I need some ideas on getting it cooler, on the cheap.
I notice that the engine bay suffers uber bad heatsoak from the alloy block. So my first thought is getting a bonnet scoop and or vents on top. Do these make a huge difference on a hot motor? I have found some pretty cheap brand new through Sydney Special Vehicles... Like this one which is only $88
Then what about oil cooling? Is that expensive to set up, is it worth it? Does it make that much difference?
What else is there? I've thought about trying to fit a bigger thermo fan in the place of the little one on the A/C condensor. And have it switched by the temp switch also....?
This is about the only engine pic at the moment on the web. It's from when it was almost 1st on the road last year.. Note the fan is on the outside here and no a/c condensor in place...
And I think this one may show some of the problem.. There's not alot of airflow in through the front. The spotlights are now a bit bigger to. Cut holes in the bullbar? Run cold air pipes up to the sides of the block?
