V8_IS200_marcus
Hi guys.
In the newyear i will be starting my Conversion on my IS200 to 4L V8 1UZ-FE thats in the Lexus LS400
i have a LS400 makeing its way to me very soon thanks to a mate, He knew that i wanted to do this for some time now, and he came over my place oneday and told me he had got a 1991 LS400 can not pick it up untill next month
The car has done 120,000 miles but then so has my IS200, so i dont only have the engine i have the rest of the car as well to get some bits off. as its been done before........i have or can get all the info i need when i need it, the gearbox is going to take most of the time to do as the LS gearbox is auto and i want to convert it to manual...........i know there are 2 or 3 gearboxs out there that will fit but i will have to swap the bellhousing over for a custom made one, am i right in saying there are 2 or 3 that fit the 1UZ Block:scratchchin:
(ECU) as for the ECU.........i dont no what i will be doing with this yet, think i will be useing a standalone....
what one i will have to look into it?
as for things like the fueling, i will be keeping the std njectors for now as there will be no need for biger ones untill i go FI
dont think i will have to mod the sump like on most Conversion,s on the IS as the sump on the 1UZ-FE sits at the front of the engine so it should fit over the cross member on the IS, think i will have to make some custom engine mounts i say think as i will not know untill i drop the 1UZ in to see.
the good thing about this swap is that the 1UZ is an all aluminum construction that makes it just as light as the 1G-FE + The Rods are factory forged units, the same is the crank.
But then you guys know this........
I will keep you all updated to how its all going, i will put some pic,s up when the work starts
