-Nemesis-
First up, I don't condone this and i'm sure some people will tell me why my motor will die or something extreme.... :saevil:
Anyways for the last 6 months my 1UZ has been idling fast when I pull up after driving, after a while at idle it settles down blah blah blah. I knew from research on here that it was most likely a dirty ICV/IAC, but the bottom screw on the black unit is stuffed so I couldn't removed it. Okay so i lived with it...
2 weeks ago it went to the opposite, it wouldn't idle at all, it just kept turning off. Whether it was cold or i'd been driving, even in between gears. Very frustrating, especially when everyone is watching this V8 monster truck.... :rant: So I tried once again to remove the unit without taking the whole thing off (draining coolant etc) to no avail.
I had another read of the planet soarer guide to see what was inside the unit. I noticed that where the main air inlet goes (from the air intake pipe) is just the plenum type chamber where the plunger is, and what would be my guess as being the gunked up bit. Nothing sensitive, no grease etc...
So, with the engine revving (slightly open throttle) I pulled off the air hose to the ICV, it stalled... yep. Try again; I pulled the hose gently off but slid it up so it was half against the ICV intake and I could see half the opening. The revs dropped but it kept running and the ICV was sucking air through it quiet fast....Excellent.
My plan: Grab a can of quality Throttle Body Cleaner, the type that quickly evapourates. In the half hole I could see I gave it a good squirt (1 sec), waited 15 sec, gave it another.. About 4 times and then reconnected the hose and let it run for a minute as is. All up, about 3 min work.
When I pulled the chock off the pedal it immediately came to a smooth idle, wow I haven't seen that for a while. So I turned the car off and started it, perfect instant idle (no waiting for ecu to relearn or whatever.) So I let the car cool down and then started it, perfect cold start high idle and reduction as it warmed (which it hadn't been doing properly for 6 months.) It's been over a week and lots of starts and it's better than ever, like new.......
Like I said I don't condone this as i'm sure people will have problems with it. But, I don't see the point in pulling it right down and changing bearings etc unless they're actually stuffed. Happy as a poig in shoit
:Eyecrazy:
:Eyecrazy:
