I need help! 1uz swap
chasemotox11
I have a 92 sc400 engine in my 2000 Toyota Tacoma I have egr and downstream o2 sensor codes ecu part no 89661-24240 cali.
I was told if I use a soarer ecu part no 89661-24220 that those cars did not have these items therefor eliminating my problems can anyone tell me if this is correct and that I can just swap ecu's. before I spend $200 on a ecu
thanks,
chase
not sure about the downstream o2's but it definitely does not have the egr equiptment. I think I may have the ecu you need and if I have it I'll definitely sell it for less than 2 bills. I'll take a look later this week when I go to my shop.
thanks,
chase
I have the '92 or '93 SC400 engine and its ECU in my Supra and the only code it is throwing is for the downstream o2 sensors. I have Lextreme's EGR delete kit installed (uses a resistor on the harness). The downstream o2 sensor code can be tricked using o2 heater simulators like those listed on my site (1uzsupra.com)
