if gasoline can cool the intake charge(and it does, when injected correctly), then so does water AND Ethanol. as for the water lowering combustion chamber pressures, im not so sure. it may lower or raise, or it may do nothing. someone would have to do an experiment and record actual findings to prove it.
You don't have to. The papers dating back to the 1940's on water injection are easily available on the internet, along with several early tinkerers. The old data is much better than anything of today & honestly more relevant.
I've not reviewed a single "modern" paper, or person/company that talks about water injection without just repeating the same old boring crap, that has become both rhetorical, and nothing more than myths.
Not so sure that the efficiency would work to your benefit though.
Exactly SCV8. A TEC's ability to transfer heat is pathetic in their efficiency. They also consume massive amounts of power in the process. It would be impossible to power, or cool TEC's on a car/engine application.
The closest thing I can think of would be cooling fuel lines, but you'd have to cool the majority of the line as the fuel flows by so fast & then you're still looking at tons of heat & electricity wasted for eh? A simple A/C system has many times more capacity & takes less power to run.
Against that idea, I use the same argument against intake manifold insulators... Keep in mind I made & sold quite a few of them too! LoL!
Sure, I was easily able to drop peak manifold temps by large chunks & keep it substantially cooler the longer the engines were run. The problem, is that it just doesn't really matter. I never got past anything but my g-tech pro comp, but I could show a few consistent whp gains with the cooler intake manifolds.
The problem was just that. A "few" whp. The air simply flows through the dang things so fast, it's really not being heated *that* much in the upper manifolds (Toyota v6).
I always apply that rule of thumb when I'm thinking about cooling airflow, gas (I admit freely that I have never done a project so ferocious it required the thought of needing to cool gas), transmission & oil lines.
pro240c
it works well in LEAN applications because it keeps the pistons from melting by cooling them - a leaner mixture is a more power than a richer mixture.
Water injection works under all conditions. It effectively riches the mixture many times what straight fuel would.
it also adds hydrogen and oxygen to the combustion process for a cleaner, fuller burn which equals more torque and subsequently more power.
Completely untrue.
The water does not split into base hydrogen and oxygen atoms... It goes straight out the tail pipe as it turns to steam through the combustion & exhaust system itself.
*edited*
Adding a little bit & reproof read. I'd say it was atrocious before, but I probably couldn't spell that after midnight.
