Here is an interesting article from Peter Scott of Planet Soarer about pully size and boost for the M90 and M112. I am also in the process to update some of the information based on his findings with the Whipple 2300 and compression factors.
This is the formula for determining boost. Credit goes to Planet Soarer:
Boost (psi) = (PR x 14.7 x V / C/2 ) - 14.7 - I
PR is pulley ratio, crank pulley diameter divided by drive pulley diameter. e.g. The stock Jaguar M112 pulley is 3 inches in diameter, therefore 5.5/3= 1.83
14.7 is the pressure of the air we live in, we don't live in a vacuum, we live in 14.7 psi.
V is the volume of the Eaton blower for one rotation. The M90 is 90 cubic inches or 1475 cc. The Eaton M112 is 112 cubic inches or 1835cc. Turn it once and it pumps out 1.835 litres of air.
C is capacity of the engine in cc : 4000 cc for the 1UZ-FE. The C/2 is C divided by 2 - because for one rotation, a four stroke engine is only half way through a complete cycle. When the piston is up the top and starts going down, air and fuel go in, then it gets to the bottom and goes back up and compresses the mixture. That's one rotation. Then the spark plug ignites the mixture and it starts to go down again, it gets to the bottom and then goes back up again pushing the burnt mixture out the exhaust valve and returns to the top to start over again. That's two rotations.
I (capital "i") is an allowance for boost lost due to valve overlap. All engines have valve overlap; the intake valve opens before the exhaust valve closes - the incoming fresh air and fuel pushes out the last of the burnt exhaust gases. The 1UZ-FE has a small overlap of only 9 degrees. Nissan's RB26DETT has 14 degrees, Subaru EJ20 has 16 degrees and the turbo EJ20 has 14 degrees. The allowance is quoted as 5% boost lost for every 10 degrees of overlap. So for the 1UZ-FE at 6 psi boost, perhaps boost loss is 0.05 x 9/10 x 6psi = 0.27 psi lost - it's not much.
Here is what I came up with based on what I have seen from other FI owners. Boost Level and pulley size
