All superchargers has to do with crank pulley size and charger pulley. Mix and match to get the proper desire boost. If you reach 1 bar at 2500, what does it means at 3000 rpm? If you get 1 bar at 2,500, then at 8,000 rpm, you will be overboosting. Its best to get full boost near redline.Anaema said:some belt driven centrifugal SCs can reach peak boost before redline. the best example i can think of is the twin Rotrex SCs in the new Koenigsegg CCX. they are designed to produce about 1 BAR of boost at 2500 RPM, the redline being about 8000. ill try to find a link.
