Anybody got any ideas on how to build the driveshaft to suit from the celsior box (3 fingered output shaft) back to the diff?
I assume I will need a slip joint somewhere on the shaft?
The falcon had a one peice driveshaft with the slip-joint in the gearbox.. of course this won't work on the new setup..
Can I get a two peice shaft made and install that without having to mount a center bearing or anything? (2 Peice shaft, with the slip-joint in between the two shafts?)
Not quite sure on how to go about this stage..![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
Help![Stick Out Tongue :P :P](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f61b.png)
Thanks,
![shrug.gif](http://lextreme.com/forums/images/smilies/shrug.gif)
Help
Thanks,
