Looks very tidy!
1 battery "-" to engine block to chassis
2 battery "+" to the big starter wire
3 ECU's BATT to battery +
4 ECU's IGSW, +B to ignition switch (temporarily)
5 Check that ECU's E1 pin (and the rest of Ei) has continuity to ground
6 Now get to the loom connectors that don't run into ECU
-use multimeter
-use your wiring diagram
-make sure to have 12v at o2s power pins, ISCV, MAF, diagnostic socket, igniters
-also make sure to have 12v at injectors
-make sure igniters are grounded firmly
that should make it
