help on 1uz mk1v swap...
beario
ive searched on here,what i want to know is how much does the supra n/a auto and 5 speed weigh???
with the 1uz fitted whats the perormance like,as i thought the supra is quite heavy???
who do you recomend for the w58 adapter plate??
and what engine mounts do you recomend???
i was going to use the 3gste flywheel and supra clutch...
thanks...
any info welcome...
Weight is approx 3200lbs, (1450kg) depending on options. Get yours weighed if you want an exact figure.
Performance is better than stock, but nothing compared to the 2JZGTE (until you boost the 1UZ)
Look at eBay, you can buy the CAD file there and get it made locally
SC400 mounts and Sump
Don't be a cheap skate and use a redrilled 3SGTE flywheel, get a properly made 1UZ one.
whats wrong with the mr2 flywheel???and do you have a link to th cad drawings...
i have the rear sumped engin e already,and will either use itb or a fish and vortech it...thanks...
