S Sprint32 New Member Mar 9, 2007 #1 I've heard people say that the cylinder head sealing becomes a problem pretty early on in the game. Is this true? If so, what power level are we looking at, and what's some suggestion's to fix it?
ToranaJudd Member Mar 9, 2007 #2 Unsure on what pressures/power, but you can "O-Ring" the block. This involves machining on the mounting surface around each cylinder.. Judd.
Zuffen Super Moderator Staff member Mar 9, 2007 #3 ARP studs and Cometic headgaskets will see well into the 700hp range or getting close to 20lb of boost.
