No intercooler = faster and more boost. I won't go back to an intercooler, the water/meth cools better.
35-40 wires. Use the diagram attatched to this post. DO NOT USE THE DIAGRAM IN PREVIOUS POSTS. Just verify that your connector / pin arrangement is the same as mine as you go. The IAC wiring might not be right but its just a matter of swapping around the outputs in the Adaptronics software.
I'd be happy to give you my ECU file. It is not completely tuned and I'm using 440cc injectors but any fueling differences are easy enough to fix. Set it in rapid learn and go for a drive.
My timing map is a combination of Cobber's map and Tai Johnsens's map on Soarer Central. Tai is a guy who did have an SC400 (Soarer actually) with a Vortech supercharger and was dyno tuned.
I'd be willing to bet, assuming that your IAC wiring is the same as mine, that your car would start and run fine with my file. My car started and ran fine the first time with Cobber's file except the IAC outputs were wrong and I decided to use VE tuning and his map was in injector miliseconds.
You might need to use different calibrations for your map (I'm using a GM 3 bar) and you'll need to figure out how to wire in your wideband sensor. You might want to find some or make some sheilded wires for the crank and cam sensors. There are a couple of things in my diagram you might not need to do. The AC wiring in my diagram is not correct FYI. I also re-wired my injectors as seen on page to of the diagram file.
Be happy to help as much as I can.
KC
KC
