After almost 4 years, two house moves, one house and garden rebuild, a change of job and multitudes of lifes hiccups I finally have my part built Lexus powered Cobra back in my garage, in my house, next to my beer fridge, and I can work on it again. The donor of the engine was a June 1990 manufactured LS400.
Back in the day I removed all the EGR stuff, replacing with blanking plates, but I left the Vacuum Switching Valve beneath it connected between the plenum and the fuel rail regulator in position.
Three questions.
1. What is the purpose of the electrically operated valve between the fuel pressure regulator and the intake plenum ?
2. Can I remove it and connect the fuel pressure regulator direct to the plenum ?
I'm not concerned about fault codes, as long as the engine performs as normal I'll be happy. The fuel pump runs at 12v permanently as I've dumped the fuel pump ecu if that has any bearing on the issue.
3. Eventually I want to put a reasonable amount of boost into the engine say 10psi plus using a piggy back ECU and secondary injectors. As the original fuel rail regulator is not designed to see positive inlet manifold pressure should I disconnect it from the intake plenum totally at that time?
Cheers,
Tony
Three questions.
Cheers,
Tony
