Steve, don't misunderstand, the Boost-a-Pump isn't a fuel pump; it's more like a voltage "amplifier".
The Walbro is a good fuel pump, but one disadvantage it has is that it doesn't like to be run at lower voltages, unless they're generated by PWM. If you feed it 10 VDC or below via a resistor setup, as per the earlier 1UZ's, it will overheat & stall.
The Supra pump is a great pump, but it's a power hog. I like it because it's a quality OEM piece, and its performance is very predictable.
To me, the combination of the Boost-a-Pump and a single Supra pump is the way to go for nearly any street application.
