Really, it isn't all that much different from the other builders of these things. It has a upgarded intermediate sprag/3rd gear(mine is a billet sprag, so possibly a bit stronger), and a few extra clutches. This transmission isn't even cryo or heat treated or any of that fancy stuff. It had a lot to do with the valve body calibration. All of the other shops use a solid rod to stop movement of the accumulators. Yes while this will make the car shift faster, you're also very prone to breaking something. The accumulators are like shock absorbers on the gears and parts.
Think of it as if your car had no suspension, and the axles were bolted straight to the chassis. You would have an extremely uncomfortable ride and probably break your neck if you hit a pothole lol. The stock shifting calibration is like what an old Lexus suspension would be. Super soft and mushy and just slow lazy shifts. What I did is installed custom spec'd springs into the transmission. Now it's like if you put a set of sport coilovers on the car. Much stiffer, but not as stiff as straight solid axles bolted to the car.
Hope that was a good analogy. Anyways I do not use any rods at all, just custom springs only. This give the gears that little bit of shock absorption to let it hold up instead of blowing up. The only problem is that the 3rd gear sprag, no matter how strong is still not strong enough to hold serious power. You have to train yourself to let off the gear for a split second between the 2-3 shift under full throttle acceleration. Kind of like if you were driving a manual transmission, you have to let off to shift. Every other gear you can hold it in, just not the 2-3.
If anyone is interested, I can build up a transmission for you to make it hold some good power. I just need to become a vendor here to do that. If it's not too expensive and I have enough interest, then I'll consider doing it.
