krayn
Hi all,
Just wondering if any one out there has experienced the same problem Im having. The engine develops a vibration around 1700 rpm. It disapears around 1850. I have a suspect faulty harmonic dampner as it appears to wobble at idle but when reved it seems to not woble. Has any one had a faulty balancer before and did it make the engine vibrate at certain rpm. Or could this vibration im experiencing be coming from another source such as torque converter or engine miss? its only just started to do this. It does this at the same rpm in 1 ,2, 3, under load, and the vibration is only slight when free reving to 1700 rpm. Thanks kris
