I have did this on a 94, but now I am trying to do this on a 97 and it is completely different. Can anyone help? My car is setting on the lift now with all exhaust off and headers/exhaust ready to go on.xirforever said:After you remove the EGR pipe running from the passenger header to the back of the intake manifold, its smooth sailing from there. But make no mistake about it, the pipe is not easy to remove, 5 bolts/nuts holding it on, two on the back of the intake manifold, two on the header collection area, and the hardest one, on the back of the motor, you wont be able to see it, but you can feel it when you search around with your hand back there.
So where does the resistor go? There are six wires on the plug.xirforever said:yeah it is a lot different on a 97. i know, i have one, lol. I just blocked it off at the intake, and put another plate in that mid section and left the exhaust pipe to motor on. If that makes any sense at all. I couldnt tell if at that mid section if its just straight through or if it has a hole going to the inside of the motor or anything, id say try and take a look at that mid section sense you have it all off and see if its straight through, if it is, i wont matter if you leave it open and you can do it just like you did your 94. I really hope that makes sense... lol
so you want to leave the whole system intact, but install the resistor?
